merrygoomba
USA
I need a set of pre-programmed eproms for the system 16 multi kit, does anyone here sell them? thanks.
merrygoomba
USA
You could try buyicnow.com ?
@djsheep Thanks,but I have no Idea what to look for on there as I don’t have much knowledge about eproms & programming,I just need someone that could sell me a set of the chips already programmed and labeled so that I can just plug them in and start playing once my multi kit arrives.
djsheep
Multi Boyz Overlord
Multi Boyz
Brisbane, Australia
There’s users on here that can help who hopefully will chime in depending on your location. @ShootTheCore could probably do it if you are in the USA.
buyicnow.com is also convenient. You email them the files, tell them the chips and they burn and send them out. All the 27c322 chips I have gotten lately have had high failure rates and I personally won’t help out with this particular multi because of this. Maybe buyicnow or hobbyroms has better stock?
mathewbeall
Mission Viejo, CA, USA
I can certainly help burn the chips - but would need you to get a batch of chips. As @djsheep mentioned - if they are used they are likely to have some bad ones in there, so get extra just in case.
Kavas
Florida, USA
I bought the chips for one of my recent multis and they all turned out great. Just emailed them a list of the roms and they marked the eproms stickers accordingly. They seem to be reliable from the two times I have used them.
So long as the multi instructions are dummy proof, it's literally plug and play. Just make sure to insert them in the proper orientation.
KalessinDB
Rochester, New York
+1. I've used buyicnow multiple times because despite having a burner (impulse bought one to prep for s16 multi) I don't have a stockpile of spare chips. I was going to order the chips from them anyway, it's literally pennies more for them to write the file, why not?
...I should sell that burner.
merrygoomba
USA
What are the exact list of eproms that I would need to order from buyicnow? Also where can I get the programs and which program goes to which chip etc.? thanks.
merrygoomba
USA
I’m about to place my order with buyicnow hopefully these are the correct ones.
Apocalypse
New-Zealand
Hi all,
just a complement of information, there's far more demand for repaired units than what we have in stock so we will fulfill your order if possible.
We're also changing the design for improved manufacturing process, so in the future there may no more be repaired units available at all.
Cooljerk
Houston, Texas
Hi all,
Even if I have to wait longer, the lack of need for repairs is better than having extra repaired stock being refreshed haha. Best of luck!
