Can you help me troubleshoot this issue with my board? I can't get it to work... sorry if i made some english errors
Mystic Warrior has 2x 27c160 (2MB x8bit) sound proms, located at 1D and 2D. The mask rom check gave me a bad "2D", since those proms are built like this it's very hard they get broken, i did infact piggyback it and tested with mame set, all good.
Then i have taken the schematics for the sound area:
I have checked anything you can see here. There are no Fujitsu TTLs but all my reports (74LS08,74LS157,74LS139) are ok. To be sure, i have changed them with new ones.
If i did understand what's going on here, those 2 proms are treated like a 1 unit (they both have CE Jointed) but since the rom is splitted in 2 parts, the OE is driven by the LS139 who "talks" wich of the 2 proms should output when is needed by the code.
Like most konami boards i have a bad Lm358 Amplifier underneath the 054986A, sound is distorted and very loud when it gets hot after a while. Custom is recapped and the DAC is ok, but since this is an output i can leave it until i fix the bad 2D. My concern is (IF) the custom underneath the module could affect this, i realy do not know what is supposed to do (marked 054321)
Any idea about what i should check?
thanks
thanks
