Kagaden
I'll be keeping mine with my cabs but hopefully someone else can drop you one if they don't need it.I'm looking for one of these to install it on my swing cab.
couldn't tell you that but I bought a shit load of these about 4 years back. https://www.arcadeworlduk.com/products/pack-of-20-x-23mm-brass-flat-tokens.html decent weight and they run through my any coin mech no probs. They look terrible though.Is there an issue with the weight. They mention a modification on the site. Not sure what they mean, but in the end do they work?
They work fine. Usually all these repro ones are magnetic so they get stuck because there is a magnet in the coin mech. You just have to unscrew it to remove it.Is there an issue with the weight. They mention a modification on the site. Not sure what they mean, but in the end do they work?
Instead of removing the magnet, I recommend flipping it and inserting it back in so you don't lose it. You can always revert it this way if necessary as well.They work fine. Usually all these repro ones are magnetic so they get stuck because there is a magnet in the coin mech. You just have to unscrew it to remove it.
Correct, you can flip it around and screw it back in.Instead of removing the magnet, I recommend flipping it and inserting it back in so you don't lose it. You can always revert it this way if necessary as well.
I had a similar issue with the arcade tokens I got. Just bought one of these https://arcadeplastics.com/any-coin-mech and never looked back.i just read thru this whole thread and i dont see anyone adressing this so il point this out for anyone who is looking. the gateninety sega and capcom tokens work in regular mechs with some adjustment and removal of magnets, but the taito ones will NOT fit thru a conventional 100 yen coin mech i bought a couple hundred or so of them and they are visibly bigger. Ps added pics
They're pretty damn great.just got my order of 300 of those AliExpress MVS coins/tokens through and compared to the 100 Yen coins I have, they're pretty damn close to them.
FYI: these are all the MVS coins. they're 100 on 1 side and MVS on the other.
regardless I'm glad I got them before that kind of thing catches up with them.They look good. I do wonder however what the legalities are cloning one side of a 100 yen coin?
