I don’t know what version marquee is on mine, but mine is not clear, appears to be some coating on it that has been partially removed due to tape it seems.
Looks like you have the proper one, make sure the thin film side is facing the front.
Yup thanks, I flipped it after taking that picture as I noticed it washes it out. Also bonus that I can’t see the imperfection as much anymore.
You got lucky, some arcade OP prob mixed them up (frosted for clear) when reselling.
Normally anything after the L-AMI was clear.
Time line:
  1. F (frosted), L (clear)
  2. Vs (clear)
  3. FC (frosted)
  4. L-AMI <-From this point forward all clear
  5. Diamond (clear)
  6. Diamond Black (clear)
  7. Diamond Orange (clear)
As I've mentioned before, I believe the L-AMI is so special because its basically the "missing link" that connects the evolution from original VLX lines into the Diamond lines.
Mines is definitely just clear. 🙁
If anyone in the So-Cal area wants one, I just received mine, please msg me. I made a slight mistake and do not need this. Packaging is beautiful though!
Got my set installed. Had to file out the holes a bit like others mentioned, but it's no big deal. I don't need a replacement.
This is the marquee that came with my vewlix. It's a lot more scuffed up than I thought. This is after I wiped it down inside and out with alcohol.
*Powerful*
I noticed it emits so much light, it actually creates an ambiance when sitting at the machine now. It reflects off of the control panel, giving a nice cool glow. It's great.
*Powerful*
You need to get the proper acrylic. In the meantime I can send you the reflective tape to put around the edge of the acrylic you have and it should at least bounce the light back down instead of scattering out the edges.
Sure that'd be great! Can you dm me the price and shipping?
So i went ahead and installed it on my DB
I fixed the center pcb (easy)
My marquee on the DB is clear ☹️..
A frosted marquee is a must its soo must illuminating.
Here are pictures with the clear one and then with my FC marquee on
@Derick2k - no need for a replacement for me on the center LED piece. I have not installed it yet, but should be no issue on my side with filing those holes slightly.
