GFI SQ Cabinet Help
lupinthe23rd
Chino Hills, CA
So i just picked up an SQ cabinet and since this is my first SQ/G-Balance cab I had just a couple of questions. I've read up on several threads here and on Otaku but I wanted to address the main challenge im having.
The cabinet didn't come with any i/o but it has the jamma harness and 30+ pin adapter board.
I would like use my TTX2 running original HDD games like Blazeblue and SSFIV.
What do I need to connect the TTX2 to the SQ?
I do have a spare Taito fast i/o, and NAJV2 but no extra Sega i/o's. I've seen previous post mention that the fast i/o is compatible with this cab but Ill need to run a proper JVS setup.
I also read about running a step down for the 120>100v. Would this effect my TTX2 performance if I ran 120v to the cab without the step down?
Any help or advice would be appreciated!
I just remembered that I can't use the fast io since my ttx2 doesn't the fast io pcie board. I do have the standard Taito JVS io that I can pull from my Vewlix. I'll be able to test this today.
