Hello from Michigan
Jetfxer
Hi, I am brand new. Just bought my first arcade cabinet, it was an old MK2 cabinet converted to a virtual tennis machine, the marquee light doesn't work, and I have no idea how to get to it, and I can't with to tear into it to figure out how.
Steve
welcome! If you look on top of the machine where the marquee is you will see a bracket with 4 screws. Just remove the screws to remove the top part of the bracket. Then you just have to pull up on the glass and the marquee.
More than likely it only needs a new bulb or a starter.
I found the screws. Looks like a bad bulb. Been doing some research, looks like I have a sega naomi system set up in there. I would like to set up a multicade system pandora 4. Any suggestions, may be a broad question?
Probably not a difficult job. Depends how the original conversion was done and what monitor is in there. If you take some pics of the NAOMI setup and wiring that will help.
Anyway, welcome. I'm also from MI so you can holler if you get stuck.
