Hello, little help with a setup.
promking
Medford New York
I have a HAS 3.0, and a 5.0.
I'm looking for the easiest solution here if possible. What I mean by that, is I might need a custom cable?
I have a 8pin to Scart cable for my HAS now... I'm looking at adding a Extron RGB 201.
What would be the best cable solution to connect to the Extron 201 from the HAS. I would need an 8pin to VGA? Does anyone make that?
I'm currently using a 20M2MDU as my monitor.
Thanks in advance.
I would say, something like 8 pin mini DIN to HD-15 Adapter should do the trick for you, 8pin mini din cable connects to HAS and this adapter then this adapter connects directly to input DB15 of Extron RGB 201. From there you can use simple BNC cables from output connectors of Extron RGB 201 to your PVM. Can I ask why are you adding Extron RGB 201 in the mix ? I mean you could go directly from HAS to PVM.
https://rgbslab.com/en-ca/products/8pin-mini-din-to-hd15-adapter
