Hi
I have the same problems with my Naomi 2.
the only thing better is it boots with the netdimm randomly and i can play naomi 2 games. after switching it off and removing then reinserting the netdimm, it wont boot again. it's hard to know when it decides to boot and let me play games from the netdimm.
sometimes it shows the white boot up screen where the naomi 2 logo starts to scroll down but it black screens in 1 second.
there are times it boots but shows error 34 when i unplug the crossover cable from the netdimm.
is there any experts that can find out which component is dead or failing on the naomi 2 based on the info i've given?
the netdimm works fine on my naomi 1 so i can rule out the netdimm as faulty. all the Naomi 2 RAM ICs are fine as i've ran the test when it was working.
i have recapped my netdimm and naomi 2 board. i can rule out the capacitors on naomi 2 being faulty. the supercap leaked and i've removed it. the row of holes nearby have blackened though. i think it's Jtag holes? i have cleaned up the area and there doesn't seem to be any broken traces. looks good like the rest of the board.
hope someone can help as i dont want my investment to go down the drain.
just hoping a rom cart is released with naomi 1 mode as at least i can still use the naomi 2 to play naomi 1 and atomiswave games if it can't be repaired.
My does not boot with any kind of DIMM (DIMM, NETDIMM in GDRom mode, NETDIMM in NET mode).
Which BIOS version are you using on your NAOMI 2?
Mine only boots with 23608, A or B. With 23608C it does not boot.
By the way the 23608C already has the capability for NETDIMM network configuration.
Regarding the Naomi 2 board recap, did you changed only the normal eletrolythic capacitors, the surface mount capacitors or all?
Do you have any list with the capacitors reference (CXX or ECXX) and its value?
Did you noticed any diference after the recap?
Don't know on the Naomi boards if bad capacitors can influentiate the board boot. Do you know?
Regarding the 0.1F Super Capacitor I already replaced it.
Regarding bad traces, mine does not have seem to have any.
Are you able to run games via NETDIMM using a PC or you allways get ERROR 34?
Best Regards,
iTRDC2
