Xisco
Hello there! This is my first post, I registered to ask help repairing a CPS2 board.
I have an hispanic Street Fighter Zero CPS2 board which, when I tested it, gives sound problems.
The sound problems were very strange: the intro has all the sound effects but no music, and in game there were some musics that play and some that don't. This same musics that don't play in-game don't play on the sound test screen.
The rom checks were all OK, so after cleaning, attaching, deattaching and doing a lot of things, I finally opened the board, with a programmer I readed the QSOUND ROMS (sfz.01 and sfz.02) and found that the second half of sfz.01 is blank. To make sure that this was the cause of the problem, I tried the game in an emulator replacing the qsound roms with those dumped ones and voilá! Same problems and musics missing which my board have, so problem found.
The thing is that the QSOUND chips are SONY CXK27C1000DQ-15 and that chip does not appear on the program I use with the programmer (MiniPro v6.50).
So after searching on the internet I found this forum and this thread from @neurokinetik where he says:
So I tried to reprogramm those chips with the Hitachi HN27C101AG-12 option. I readed them but not perfectly with this option, so when I used ATMEL AT27C010 (don't remember why I ended trying that one) I got a proper dump of sfz.02 and the first half of sfz.01 (because the second half was blank).
But the thing is that I can't get to reprogram them, probably because I don't choose a proper suitable compatible eeprom. I erase them with UV and programmed some program CPS2 roms before, so the programmer seems to work correctly.
Is there anyone here who can tell me which option should be compatible to program this eprom? I don't know how to figure it.
Thank you very much!
The sound ROMs were Sony CXK27C1000DQ-15. I burned Hitachi HN27C101AG-12 to replace them, as my burner does not have a listing for the Sony devices and I wasn't 100% certain that using one of the substitute chip settings was working properly.
