good afternoon to the arcade project community I have a hummer extreme edition that the hdd failed and I would like to know if I can put a sata or ssd in it and what do you recommend or if it is only compatible with hdd ide as it comes originally
I'm pretty sure that using a SATA drive means having to turn it into a multi, i think Lindbergh only reads from IDE drives.
Maybe with an IDE adapter but last time i tried one to try and get a Rambo back up and running, it never saw the SSD on the IDE bus
Otherwise a multi will be needed. Remember the PATA -> SATA board might need to be adjusted so it’s set to ‘Slave’. There are also speed settings which may or may not affect compatibility.
