HardAzRockz
Hi all,
I recently purchased an SSV (Sammy / Seta / Visco) arcade board with 4 in 1 Multi from eBay (seller based in HK). Unfortunately, when I power it on, I’m getting garbled graphics on screen — however, sound and music are working fine.
Here’s what I’ve done so far to troubleshoot:
The seller claims the board was tested “multiple times” before shipping.
Questions:
Any advice or things to check would be greatly appreciated before I go through the hassle of returning it.
Thanks in advance!
Here a link to a video demonstrating the issue.
View: https://youtu.be/FF0VvSIou8s?si=MLXfld99EQuIyiM3
- Re-seated the ROM board several times.
- Removed, cleaned, and re-seated all socketed chips (including the DIP sockets).
- Carefully inspected both boards — no visible damage or corrosion.
- Noticed the system board has a slight sag in the middle. I lightly pressed on each chip while powered on to check for intermittent contact — no change.
- Checked for obvious broken traces or bent pins — nothing found.
Questions:
- Could this be an issue with the ROM board or the graphics-related custom chips?
- Any recommended next steps before I request a return?
- Is sagging on SSV boards common, and could it cause this kind of graphics corruption?
Thanks in advance!
