Maruchan
So i have had my blast city for a while now, i been trying to get my 360 to work on it. when i first got it , i was able to hook up my 360 via VGA and it worked just fine. some reason it had no sound coming out.
Then i got this cable that connects the red and white audio cables from 360 into the actual jamma wiring harness. after connecting everything i was able to get sound but no video? my jamma harness works fine if i put in sf2 with jamma or even my pandoras box 4. so any suggestions on what i might be able to do?
EDIT: Controls , i will get to when i can get the video and sound to at least work. Controls are least of my worries.
EDIT: Here is what it looks like when i have my xbox 360 connected via VGA
(http://i.imgur.com/Jz0u6lO.jpg)
The screen looks fine when i use jamma on my pandoras box 4
UPDATE !
FIXED !!!
The issue was that it was stuck on 15k and not 31k just like some people suggested.....
what I had to do was disconnect everything , hold down the up and down
button on my OSD adjuster for about 3 secs and it runs a auto reset
kinda thing.
I was able to figure out how to do a reset on my frequencies by googling "how to adjust hold on 2931"
it pulled up a PDF file of some monitor specs and troubleshooting things . i then tried one thing i saw which was to hold the up and down button on my adjustment panel for 3 secs without any inputs connected
To confirm it wasn't my xbox or my xbox cable that connects from xbox to
vga monitor . I connected it to my security monitor we use for our
cameras (it has vga). It was already set to 640.
So it worked and then I reconnected everything back to my blast city and then BAM , it got video and sound
Now i have to try and see the best option to run 360 controls to the joysticks on the blast city !
i would like to thank all of you that gave any input at all. Any input helped at the point of my frustration.
(http://i.imgur.com/kGADjxl.jpg)
UPDATE !
FIXED !!!
kinda thing.
