Hub / Splitter usb for SEGA I/O JVS NNC
chacal231077
France
Hi!
I would like to know which model Hub / Splitter usb supply + 5v or + 12v advise me to connect at the same time a JVS to JAMMA - River Service
and another JVS system to the sega I / O New Net City to avoid too much connecting and disconnecting the usb cable :?: :love:
Thanks :thumbup:
Ok,
That is not a usb spec connection. Sure it uses a usb type header/plug but it is a completely different protocol. DO NOT plug these into a USB hub/PC/etc...or you might damaged something.
So...if you really need to have these on a switch you will to make one or find one that is basically a mechanical form of switching the signals. The USB ports cannot be powered.
Good luck in your search for a solution.
  • Like
Reactions: nem
yes I know The JVS signal consists of 4 signals:
- RS-485 A (data transfer and sharing, speed 115200 baud)
- RS-485 B (transfer and data sharing, speed 115200 baud)
- SENSE (point-to-point connection)
- GND :)
