Hydro thunder audio problem
zedmekis
Canada
Hi,
I have a Hydro thunder that have no sound at all.
the audio cable is working
the amp is working
the speaker are working
there's no sound coming out of the computer I tested all the part in another hydro thunder so I was wondering if it's possible to install a sound card or something like that to workaround the problem ?
thanks in advance
A separate sound card won't work. The game is programmed to use the motherboard audio chipset.
When booting the game, does it pass the audio system check?
Hi,
yes the game pass every test even in the test mode everything is good that's why I'm puzzled about the problem
If you've swapped computers between cabinets and the lack of sound follows, and you're sure that you've plugged the audio output cable in to the correct port, then you'll have to either replace or repair the computer.
Repairing would mean identifying the audio section of the motherboard and then finding whatever (likely surface mounted) component is faulty.
