Improved WiPi Netbooter SD Card Image
CamoYoshi
Burien, WA
A flaw I noticed with the official 32GB SD card image for the WiPi Netbooter was that the SD card it was imaged from had a nominal capacity of 31.9GB. A lot of SD cards on the market that are sold at 32GB tend to have a slightly smaller capacity ranging from 31.5-31.8GB. The OS partition that runs the DietPi install gets cut off as a result when being written to a SD card, resulting in it not booting up. I have fixed this by doing some work to shrink both partitions, leaving some empty space at the end of the disk image (this also results in image file being smaller so it's less to download!). Other than that, this is just as fully capable as the normal image with all the games and support for all NetDIMM platforms*. Some other minor quality of life improvements that I've done to this image:
- Enabled the Time Hack setting by default
- Preconfigured a Sega NAOMI 1 NetDIMM to be present at IP address 10.0.0.3 (this is per the recommendation of the manual)
Notes:
* I have only tested this modification to the image with a Naomi 1. If others who have Triforce/Chihiro/NAOMI 2 could test and report back if this works I'd appreciate it! I don't believe there is any issues with it not working as nothing should have changed, but I don't have a way to confirm this myself as I don't have a Triforce/Chihiro/NAOMI 2.
Downloads/Instructions below:
Code:
WiPi6-1-4-2.7z.001 14B7BAD50FFB1D7FDE66AFAA83EC65C85EFF8DAA95712E687C81E99346000846
WiPi6-1-4-2.7z.002 78B6C8B4B1CAD11C4AD9CE6CC483131C57EDFD2322BC5B4B236CDA4C37EEF762
WiPi6-1-4-2.7z.003 EC1B9724FF513152F935605C5A52E3AF497C005BA5B2B322EEC50C670DB50151
WiPi6-1-4-2.7z.004 5FA9B4D5BAAD913A3F054CC48E569F6735F445D0130281F5EBA5B85A7356F6BD
WiPi6-1-4-2.7z.005 20DB95F82FBFD04957A412330F48EBC6D886E2F9B59FA1207143938F16E94F3D
WiPi6-1-4-2.7z.006 669913F18D97C03AFC4CD570D62953C048C9E6D83D11BA6E35DA3AB8E9CE1C03
WiPi6-1-4-2.7z.007 7515135948381EFA3442FF70F160F3157CDF0864A8177EE9721A7E8D5FEC02BA
1. Download the files and confirm checksums using a checksum utility, then extract with the archive manager of your choice.
2. You should have a .img file. Write this to your 32GB MicroSD card using a raw disk writing utility.
3. Once complete, safely eject the MicroSD card from your computer, and insert it into your Raspberry Pi that you are using for your WiPi Netbooter setup.
4. Power up the Pi and wait approximately 60 seconds. Check for the WiPi-Netbooter SSID to appear and connect to it using the password "segarocks".
5. Open your web browser and go to http://192.68.42.1/
6. If a game list appears you're all set! Note that you may need to reconfigure your NetDIMM's configuration through the test menu. Make sure to select "SET" on both the IP Address and Netmask settings after configuring. For it to "just work" I would set the IP to 10.0.0.3 and the Netmask to 255.255.255.0.
