WTB Initial D 7 AAX Shifter
Want To Buy
PaulWoodpross3r
Memphis Police Department
Hello,
Does anyone have a spare shifter for Initial D 7 AAX or Stage 8 available they would be willing to sell for me working? I am planning to swap out the shifter in my Le Mans 24 (Model 3 FFB) cabinet with this one, as I think this shifter is ridiculously comfortable having played the Initial D Arcade Stage 8 cabinets at a Round 1 not too long ago. I believe it may fit my cabinet but I will have to make an adapter to connect the wiring harness to the dashboard. Lemme know if you have one!
This one here:
https://www.arcadespareparts.com/ar...nitial_d_aax_gear_shifter_assembly/13804.html
Assuming it's the same dimensions as the one used in Initial D 1-3, it'll definitely fit in place of the Le Mans 24 shifter. The only one that needs clearance help (as far as I know) is trying to use the Indy 500 one in later games like Crazy Taxi, Initial D 1-3, or OutRun 2. The older one needs extra clearance at the top and bottom of the hole that they stopped bothering to add, so just a little metal chopping on the mounting plate. The later ones should drop into an Indy 500 panel with no issues.
