Inverted colors on ms8-26
spacejockey
France
Hi there !
I have an issue with the display of my ms8-26 monitor inside an Aero city.
The problem appeared yesterday when I changed the game system installed inside the cab (cps2->mvs4)
Before I changed the system the screen was performing normally.
After I changed, the colors were off.
I tried with other games, but the problem is persistant.
When I went in the test menu of the cps2, i realized that all the colors are displayed ... but they are all inverted as you can see in the photo.
I checked the wire connections to the monitor and the jamma loom. Everything seems fine.
Does anyone has any idea what could be the source of the problem ?
Thanks for any info you could have.
Silly suggestion, but have you tried degaussing?
Demag button is right next to the power button. I've pressed it on accident a few times...
Oh boy ! How did I not even thought of that !
That solved the problem immediatly.
Thank you so much @nem 🙏
  • Like
Reactions: nem
