Is a Naomi 2 HDMI Port Screen Lag of .15 Seconds a lot and still playable
Cat
Singapore
This is a Naomi 2 Multi Kit with a HDMI Module
That's like 9 frames of lag. Sounds pretty bad. Where did you get that number?
Is this a JojoUltimate creation?
Read this thread first...
All the current HDMI models I have seen are just using a VGA to HDMI adapter internally, and not good ones - hence the lag, video noise etc.
Stick with an external solution for now.
Alternatively, show some support for @citrus3000psi to work on his Naomi 2 HDMI mod
the lag will be more than that.
CRT's draw data to the tube as it enters the monitor,
LCD monitors buffer the frame in ram before updating the panel.
if you look at monitor specs, the better monitors will tell you the input delay.
A good LCD will lag a CRT by 2ms, it's not really a factor.
  • Like
Reactions: nem
