Kabuki replacement?
LetsPlayCafe
Monroe Wa, USA
Have a Saturday Night Slam Masters with a bad Kabuki, phoenixed the board and have it working with the Kabuki from my Punisher but I only get a black screen with the existing one.
I know this process puts the Kabuki into Z80 mode but trying a vanilla Z80B doesn't seem to work so I suspect there is still something left of the Kabuki mode. Or I am doing something wrong.
Anyone have a working Kabuki they will part with? Or a way to use a Z80 in it's place?
Thanks,
David
A or B will be fine, they just run faster - if you have a faster clock.
As a direct replacement on the cps1.5 the z80 A or B they are not working.
Tried and tried again.
As a Kabuki substitute you should only use 2,5 MHz Z80.
We avoid giving wrong information please.
Obviously you have to make the modded to hardware and have the decrypted code...
Thanks,
David
I probably have a kabuki chip around here if you are interested you can have it for shipping cost.
