Kaneko Supernova BIOS files for universal Cyvern and Sengeki Striker
Tailsnic Retroworks
Spain
With @Darksoft 's permission, I upload the following files for the community. The real work is for him, and I have been helping detecting bad scenarios.
First of all, you can't use any motherboard for Sengeki Striker because is region protected inside. So, here I put the concrete eproms files for converting Sengeki Striker for all the motherboards. Flash them with 27c4001.
For Sengeki Striker and Cyvern, you need KANEKO Supernova modified BIOS for making real universal any of the 5 different motherboards exist. Only to flash on 27c4001 eprom. You can use Japan BIOS perfectly on any motherboard. You'll have glitches on boot screen if the game region doesn't match BIOS region, so don't be scared if you see garbage.
Also, I put the correct tables for converting those games on ROM-2-BOARD, ROM-3-BOARD and ROM-4-BOARD. Sengeki Striker only can be converted in ROM-3-BOARD and ROM-4-BOARD, and Cyvern can be converted with any of the mentioned.
For Sengeki Striker on ROM-3-BOARD, you need to install both SPRITEGEN-102 and SPRITEGEN-103 one above the other, being 102 on bottom and 103 on top. You have to join all the legs of the memories, except of SPRITEGEN-103 rom pin 12, which has to go to U10 PIN 12.
Awesome job!
