Konami 5k Sound Pot replacement?
ekorz
Multi Boyz 4 Pi
Multi Boyz
Boston, MA
I think my Quiz Gukamon -> TMNT2 has a wonky 5k sound pot. I bought some cleaner to see if I can make that work. I'm also probably going to try swapping the two pots since I'll likely run mono for now, and the board has both left and right. But I thought I'd see if anyone out there has any dead boards with spares, or if any of these would work. I'm not sure if the voltage rating matters, guessing it's like a cap where the higher the better...
https://www.digikey.com/products/en...wproducts=0&quantity=&ptm=0&fid=0&pageSize=25
Thanks!
Generally the volume pot trims pre amped audio so yeah no worries voltage wise.
Long as you get a 5k Linear you're good. Hopefully someone knows one that fits easily.
