Konami Simpsons Bowling - Several Questions.
ForestOfDreams
Utah
1.
Pcb seems to work but has bad audio interference.
It doesn't appear to have a ton of capacitors so I am wondering if this is normal?
Motherboard is a ga829 I think it was only used for this game.
Might be bad caps as it gets better as it warms up.
2.
Board has an unused connector labelled audio out. Has anyone successfully used this to get rca audio instead of jamma only.
3.
Is there a way to spoof the trackball and use a stick instead?
Trackball doesn't seem to do much a stick wouldn't.
4.
I did not get a harness with it, it was as is, does anyone know the connector type for the trackball and I can fabricate one?
5.
Tips or known issues? Seems to be fairly uncommon game.
Figured out the trackball connector is a jst 0.98.
Would appreciate a pin diagram to wire it up if anyone has one.
I do not have any original trackball.
