Mrhide
well I tried .... and it works
... so for anyone wanting to give it a shot, here's how the battery reveal itself as you dremel your way in
The top tab is ground and is pretty easy to keep a big piece to attach to.
...and then I broke it
.... it's DEEP ... don't afraid to dremel away (wear a mask! lots of small particules)
finally I figured out you can't remove the battery from its holder, you have to insert a screw driver underneath and gently lift it ( cover your pins below as you work)
