Konami windy 2 Power supply issue.
Legend
USA
Have a Konami windy 2 cab that powers up but Naomi is not coming on. Already tested the naomi in a Net city and works great. Most likely a power supply issue? If so anybody know who may be able to overhaul the power supply or where I may be able to buy good working one?
There are 2 different ones, which one do you have?
Ill look at the model and post details. Thank you.
If it’s the open frame with no fan, it’s generally the Tonkin power supply, same one that’s in a lot of the cyberleads. That one is prone to overheating and problems in the 12v area being too high.
The cosel one is much nicer, but the design is worse with a power distribution block. If that pcb goes toast, generally the sound amp won’t work, or you might not get 3.3v.
