Lightgun Multi Devices?
ggallegos1
Virginia Beach
So google isn't helpful right now.
There's only two other cabs I want, a Vewlix and some sort of lightgun cabinet. I was curious if anyone has either made a Pi setup or one of those Pandora carts with just lightgun games, and google is showing me a lot of arcade1up stuff. Anyone have one and want to share pros and cons?
I guess the only way to play light gun games is though emulation with a PC and there are many setups you can use (Wiimote,AimTrak,Sinden,etc.)
gaming consoles or real arcade hardware.
PC emulation is the only "flexible" option at the moment as it's much "easier" to setup and there are a bunch of useful tutorials out there. not to mention the many peripherals and being able to use and LCD. Gaming consoles will still require the use of a crt tv (unless its the wii or Playstation 3 which uses sensors) and real arcade systems are the hardest to set up as they will need the main system,the i/O boards, guns, or other parts like sensors and cameras. the arcade hardware will also require a CRT unless they use IR LED sensor technology.
