Memory/Simm Check Q's
DanyoGusto
Milwaukee, WI
Hey all,
Getting my motherboard prepped while a cart is off to get SuperBios converted and had a question about the Simm and Memory tests. Memory test comes up completely clean, but the Simm test tells me Simm 2 is "NG" and Simm 7 is "Skip". If my memory is correct, Simm 7 is normally skipped, so Simm 2 is my concern. I've only been running Third Strike without a hiccup. Considering Third Strike requires the maximum Simm size for each slot and how its been running fine, I'm curious what could be and if I should consider replacing the Simm or not worry about it.
How are you testing the simm with the cart out to be service? If you ste testing with a superbios cart. Simm 2 will always report a NG
I did the testing before packaging the cart. Just to be sure before I sent it off, I did the initial contact cleaning of the simm and the slot and tested it.
