MODEL 2/3 Stereo Amplifier Suggestion
rtw
Norway
A few weeks ago I got hold of a Zero Gunner Model 2 PCB :D
Been working on the harness and today I managed to get everything together.
Only one snag I need a simple stereo amplifier, there are literally tons on them on eBay but I was wondering if someone here had a suggestion ?
PCB with components is OK as long as the input is RCA.
The Lepai LP-2020A+ is pretty much the go-to small/cheap amp. they're super cheap, they look nice and they have comparable quality to amps twice their price. I run one in my Kraylix cab
there are lots and lots of video reviews for this thing. I just picked a random one above.
  • Like
Reactions: rtw
Thank you for the suggestion twistedsymphony :D
To be fair I've been looking for a comparable class-A or A/B amp; something that will trade off the LP-2020's low power consumption for a bit cleaner output, though I've yet to come up with a solid option.
if you're unfamiliar with Amp classes: http://www.audioholics.com/audio-amplifier/amplifier-classes
the LP-2020 is called a "Class T" which is a sub-set of Class D amps.
  • Like
Reactions: rtw
Thank you for the AMP class description :D
I am also thinking about mounting a small amplifier on the harness itself so that I have a JAMMA solution.
I would of course do a proper stereo to mono with summing resistors like described here:
http://www.rane.com/note109.html
Anyone have any small amps to suggest for this purpose ?
I have a few TDA7297 based amps in my cabs that lack them. They're like a couple of dollars each on eBay.
They're stereo, they're 12V powered, they're small, they sound OK. The ones I have have headphone inputs, but you can just grab a RCA to headphone adapter.
I second the TDA7297. I also have a Lepai. Both work great.
Thanks for the heads up on the TDA7297 gentlemen :D
