Monitor displaying Vertical
Raoul Juke
Australia QLD
Well this is a new one.
Image is displaying vertically when set horizontal L when I put in a horizontal pcb, the same issue .
Kortek chassis into a Samsung 51 tube. Chassis & tube was purchased untested in a cab with a damaged neckboard & had been sent off to be repaired & serviced , but on reinstallation I got m met with this. The image also have oversized lines. What is going on here???
This is an insane guess but judging from the really bad convergence, I have a feeling someone rotated the yoke 90 degrees. This technically works but will have really bad convergence as shown here.
It's as good as guess as any. No idea why u would do that, but very possible
It's possible someone wanted to run a vertical game but couldn't/didn't want to rotate the monitor. If someone knew enough to rotate the yoke to do this, then they should know enough to know that this is a stupid idea lol. It might have also just come loose.
Take a picture of the yoke, it should be obvious if it's 90 degrees off.
Based on the bezel you probably can't rotate the monitor in that cab.
Definitely a novel approach to fixing that issue.
