MOTO GP HDD
crazyjojo
china
I have found a s256 within motoGP,the game shows in wiki and guru's list,but I cant find the CHD.It works OK ,just a motobike racing game,Im not sure the chd is missing or not released at all.if anyone interest to it,I think I can copy the HDD image use RAW tools.but I have no idea of copy memcard,its number is NM00039,cant be found in dongle files either.
PS: the s256 looks same as 256A,but with a (+LH) version label, not a normal 256 Assy.
The 256 L+H is the exact same as a regular 256 but it has the Ethernet port installed, its used for linking two or more systems for co-op play or connecting to Namco servers.
I just take the HDD and mem to normal 256 with a test,works fine.+LH only add a LAN port chip.
To answer your question if the game has been dumped, the answer would be yes but it hasn’t been released publicly. Kinda a shame as this version of MotorGP seems unique.
You need someone to dump the memory card. I can do it if you want to send it all the way to Finland.
As for the drive, you can dump it yourself, but if you're using Windows, please use a USB connection to do it with USB Write Blocker enabled. That way you can be sure Windows won't write something over it making it unusable on the 256.
EDIT: I'm just reading Guru's update on the game. Considering @ekorz donated towards the dumping, maybe he has the files?
