Breakaron
I've had a Blast City with an MS 2930 monitor inside for a couple of months. I've managed to get a stable Mister Jammix set up in 15khz mode via Jamma. 31khz however, has not worked the entire time I've had it. Any attempts to hook up a 31khz output to the monitor via VGA yields the same result: no power to the monitor. The rest of the cabinet functions perfectly, lights turn on, speakers work, PSU fan on etc, but the monitor refuses to turn on when the dip switches on the remote board are set for 31khz. The tube makes a buzz/static noise every time an attempt is made but ultimately it doesn't seem as if power ever reaches the tube. Sometimes you can hear the tube discharge but I've never felt static coming from the screen trying to do this.
The chassis has been recapped and serviced, the exact history of which I'm not entirely sure. However I know the flyback is original. There was evidence of the "black goop" leakage happening at some point on the chassis tray but there's no trace of the stuff on the board. I also know that 31khz was functioning just fine up until maybe a month or so before I acquired it.
Dip switch settings are always as follows when trying 31khz:
1 - Off
2 - Off
3 - On
I've attempted to connect a Dreamcast to Toro box in VGA mode, hooked up to the monitor via VGA as well as a Mister outputing 31khz over VGA, hooked up to the monitor via VGA to no avail.
Changed the toro box / Mister to output in 15khz and hooked them up over VGA with the right dip switch settings ( 1 - Off, 2 - On, 3 - On) and they function perfectly fine, monitor powers on and I get a stable picture, so that rules out the devices themselves and the VGA cable.
Before I take this thing to get looked at again, I just want to know if anyone could provide some insight to this specific issue. If anyone could point me to something I can check on the chassis to figure out why this is happening I would be very grateful. I'm willing to troubleshoot but I have no idea where to start.
To reiterate - in 15 khz mode everything functions well, the picture is nice, adjustments on the remote board work as they should, speakers fine in mono and stereo, zero issues. This is over VGA and Jamma as well.
Thanks for your consideration.
1 - Off
2 - Off
3 - On
