One of my MS9 monitors is gradually loosing green after being turned on. It doesn't completely go away, but I'd say the green color is reduced by 25% or so. It's very noticeable.
Basically, if I turn it on and bring up the RGB bars from the CPS2 test menu I can see the green color slowly reducing in intensity. After just a few minutes it stabilizes.
This monitor has had this problem for quite some time. I did a recap on it a year ago, but it didn't have any effect on this particular problem. I haven't given it much thought really, the easy "fix" was to crank the G CUT OFF pot up quite a bit (which means that the monitor is extremely green when cold started, but looks totally fine after 5 minutes). Actually, I'd say this is one the better monitors I have. Almost no burn, totally sharp, great convergence and no geometry problems.
Anyway, I was moving the cabs around today and thought I'd take a look at this today. I've checked all the solder joints on the chassi and neckboard and fixed a few suspicious ones, but it didn't change anything. Also changed the G CUT OFF pot to a new one, but no change.
Any ideas what to check next?
