Multigame JAMMA options
mrnewland1
Columbus, OH
Hey guys i have an old eSWAT arcade cabinet (game works). Everything is original including original 19inch crt monitor and mono speaker. wanted to get a jamma switcher and hook up some sort of multi game board such as a Pandora. Any suggestions for multigame jamma board? Any input would be greatly appreciated.
None of them, they all suck.
Rpi setup is okay but has its caveats, pain to setup and video output isn't %100. It's highly customisable if you know what you're doing and with work good results can be obtained. Little bit pricey for what you get though.
Original MVS board with Unibios 4 and a 161-in-1 cart is a decent relatively low cost option.
Depends on what you expect, if you just casually want to play some classics the Pandora does a good enough job.
If you want to step up the foodchain grap a RPi but setting up decent is/can be a struggle.
Nothing beats a genuine PCB though, so make sure to grap the upcoming CPS1 multi or grap some of the already released multi’s like Taito F3 or CPS2 :)
