Hi there !
First, sorry if this is the wrong section for this, i was not sure... I'm searching for some definitive answers about the stereo mod (and 5v mod) on a MV1B board. There is a lot of information about this mod around, but maybe too much as a lot of conflicting ones. Plus, a lot of them are very old...
For now, i think there is two main modifications available:
Many thanks in advance for any help you could provide!
Cheers from cpasjuste.
- Neobitz mod
- MKL mod (amplified)
- I did found some people saying the MKL mod is not needed at all on MV1B, is it true?
- If i want to run the board with 5v only, do both stereo mods require the 5v mod?
- If i want to run the board with 5v only, do i need to disable 12v in any way?
- Will audio output via the jamma pins with this mods? I don't think so, but is it possible to do, maybe like this?
- I'm unable to find pcb/gerbers sources for any of this mods so i can produce/build it myself, do you guys have some links?
