MV4FT sync fix
system11
UK
If you have bad sync on a MV4FT look at the 100 and 470 ohm resistors on the sync line, they're switched compared to every other MVS. When I worked out what was going on I found a few notes about hacks for the issue on this exact revision, dont bother adding resistors just swap them, PCB was screened and assembled wrong at the factory.
