MVS 4 slot vs any other
pierpa86
Italia
Hello guys,
I'm having a curious problem on a 4-slot mvs base,
there seems to be some problem playing the audio correctly,
but the strange thing is that it only does it with the 4-slot base,
all the other bases work. is there any difference between the audio management in this base?
4 Slot
View: https://youtube.com/shorts/pCRjF6hnUEA
2 Slot
View: https://youtube.com/shorts/QbYcIODuuTo
One more question, do you think should i not use 29f1615 memory for C rom ?
Any one have problem with that ?
I haven't experienced this noise in particular but what bios is in the 4 slot.
I have decided that mine does not like Unibios 4.0 and went back down to 3.0.
With 4.0 I was getting difficulty starting games with sound and if I did get sound after cycling in attract for a bit, sound would drop out.
Also, my original Nam in somewhat odd in that even when it's working fine, if I put it in slot 1, the 4 slot starts at slot 2 and then cycles around once before going into Nam's attract sequence.
Cool cab by the way!
Sounds like the 4-slot needs to be cleaned and clear the backup ram.
Done, seem its only happen with Nam with intro, since this is not my cab :-D i'm poor... i will test one without NeoGeo gigle on start.
I put unibios 4 in two 4 slots systems and also have sound issues now. If I have a cart in slot 1, sound will work for all games. If I remove cart 1, there's no sound at all. Not even in test mode, not at boot, nothing. It's like it's talking just to cart 1 for some sound data. Put 3.x back in, works normally.
something really wird with 4 slot MVS, but i solve this issue in a creative way.
It's a known issue on multislots with the Unibios, I think. Moving the games and/or clearing the backup ram may help.
