Mysterious Naomi 2 GD ROM behaviour
ZERO_MILES
Sao Paulo, Brazil
Hello there,
I recently set-up my Naomi 2 + GD ROM setup, played a few rounds of CvS 2 and turned it all off. Half an hour later, I tried to turn the system on again and...
- It boots up, recognizes my net/GD DIMM;
- says "checking memory" (starts at 31%);
- then begins to load the game (drive spins, seeks, reads, etc).
And then reboots to an ERROR 25 - CAN NOT ACCESS GD-ROM DRIVE screen.
I've throughly cleaned everything, checked my +5v, 12V and 3.3V, they all seem to be OK;
I've tried using only the ATX PSU (that juices the GD ROM) for both the Naomi 2 AND the GD, and the behavior stated above occurs;
I've tried using two PSUs (one switching power supply for the I/O and Naomi 2, another one just for the GD ROM) - this gives me a "GAME IS NOT ACCEPTABLE BY MAIN BOARD".
Yes, I tried changing the game for another one (VF4 Final Tuned), same deal;
Yes, I tried playing a cartridge game (MvsC2), and everything is fine;
Yes, I've checked all cables, voltages;
No, I did not hook up the GDROM power harness the wrong way (mine is "keyed", it cannot be plugged upside down);
All tests I could run from the Naomi 2 BIOS seemed to be OK.
The only different thing I did recently, was replace the GD-ROM's fan for a new one. My GD drive is totally different (inside, at least) to this one: http://cc.arkadtorget.se/naomi_gd-rom_cleaning.html. I believe it's working properly, because it is oriented the right way and it is spinning freely.
I'm not 100% certain, but I think the original fan had a 3-pin connector with only the red (12V) and black (Ground) wires, while the new one has all 3 wires (yellow, for the tachometer/fan speed function).
Any tips? This is driving me nuts, I can't seem to pinpoint the problem.
