SpiritSaiyan
Hey all. I've semi-recently began having issues with my 256 setup to where it would either get stuck on a black screen or a white screen randomly. Happens with multiple games, and I've tried several DVD drives, yet the issue persists. On either screen, pressing start or putting in a coin will cause games to do a little sound effect, but then nothing further.
I've checked the 5 volt and 12 volt lines at both the power supply and on the JAMMA I/O. On the power supply side, readings were around 5.5v and 12.8v, while on the I/O they were 5.07v and 12.6v. I've read that the sweet spot for the 5v line is around 5.05v, so I don't think that's much of an issue. I did, however, read a dip in the 5v line that went down to 4.9 volts for a moment, and the system freezed around the same time.
Oddly enough, after multiple restarts the issue goes away. On a cold boot though, it'll usually freeze within a couple minutes and needs to be restarted a couple times.
Would this be an issue with the power supply, or bad solder joints on the board? The dip in readings tells me it could be the power supply, but since the freezing stops after a couple attempts that makes me think there's cracked solder joints on the board. I'm not too knowledgeable on this stuff, mostly just going off of what I've read online.
Any suggestions or information would be greatly appreciated. Cheers
