If there are any Namco System 369 owners who could help with a few questions it would be greatly appreciated. I recently acquired one running TT2 so looking for some basic answers before going forward
1) A TT2 manual - I've searched high and low for a manual and have turned up nothing. If anyone has found an electronic copy and could send me a link that would be very helpful.
2) A label on the unit above the power inlet states it accepts AC voltages between 90~264V. This appears convenient but is it as simple as plugging any voltage in and the unit converts it to what it requires? I've taken out a JAMMA switcher once that would run on 110V and 240V (just the once though). I can supply either 110V (step down) or 240V (direct mains) but since there is an outlet plug on my Blast City (that allows rows of them to be daisy chained to a power source) that would supply 110V to the unit that would be more convenient rather than having a separate power source supplying 240V to it. I assume there is no jumper or switch involved due to voltage variation but want to check.
3) Can the system output at 31khz through the VGA port? I've read contradictory posts saying it does and it doesn't if dipswitch 2 is placed on. I've got trisync monitors in the Blast City cabinets that operate at a maximum res of 31khz. If those don't have the required resolution would a quad sync CRT be any better. I've read that some quad sync monitors will go up to 1280x1024 res but that is model dependant. If TT2 native resolution is 720p or 1080p I would need something suitable that fits the cabinet. If I can get TT2 on a CRT set up in the Blast City that would be great, an HDMI LCD outside the cabinet is the much lesser preferred option. I've also started investigating video downscaling convertors which may be of some assistance but maybe not ideal.
