Nanao messy image I don't know how to describe it
man1aco
Brazil
I don't even know how to describe this defect to search on google
NANAO MS8-26SU
which game are you running? is that king of fighter 98 ?
are you on low (15 ) or high (24) resolution? this connector on the chassis allows you to select one or the other ( it should be on low if you are running KOF98)
All set corretc to LOW 15khz , I have some spare boards for parts , I can replace this sync PCB
Also the caps in that area should be replaced, along side with the ones in the vertical out area those chassis, are prone to fail there due to the heat and the weight of the two heatsinks.
