jcmorrisii
Hello again friends! Today I'm bringing you another concept I've wanted to make for a while but just finished up!
This is a Remote Board Adapter Plate (RBAP) for use with the Nanao MS9 in a Konami Windy cabinet.
The Konami Windy came with a chassis that is prone to failure, the Toshiba PB6643-1. A common (and much more reliable) replacement option, is using the Nanao MS9-29 in place of it. Inside the Windy control panel compartment, there are posts and a screw hole that line up perfectly with the PB6643-1 chassis remote board. The problem is, they differ slightly from the placement on the Nanao MS9 remote board.
Enter the Windy / Nanao RBAP! I designed this for all of you fellow Windy owners you had to swap a Nanao MS9 to keep it going! This remote board adapter plate fits snugly onto the post mounts inside the Control panel and allow you to safely and securely mount your MS9 remote board.
Fits snug on the original post mounts.
Provides a cover for solder side of board.
Sits flush with PCB and provides sturdy base at 4 integral points.
Allows mount to original screw hole.
Cutout on back for ease of access to ribbon cable to chassis.
I do EVERYTHING myself, from engineering to the final packaging and shipping. Im printing these on Hatchbox True Black and True White PLA. 25% Infill with a Grid and 4x walls for extra structure.
These are available directly through me here in Black or White (send me a DM) or on my Etsy . $15 + shipping
Links:
Humbler Tools on Etsy
Twitter
![Astrocity [astrocity] [astrocity]](/styles/default/xenforo/smilies/gaming/astrocity.gif)
Links:
