I have a netbooting Naomi 2 that is suffering from an odd and intermittent issue. It's connected to a raspberry pi running standard piforcetools. It's running Bios 23606c-multi.ic27 "Rev C" and a Zero PIC on the dimm.
I'm used to this process:
Turn it all on, Naomi 2 successfully boots to "Checking Network" screen.
Ping net dimm from the pi, success
Select game on pi
Naomi 2 resets, returning to "Now Loading" screen
Game transfer complete
Naomi 2 resets, checks memory (...yes I can disable this now, just isolating variables so I kept it in the script for now
Naomi 2 resets again, finally booting the game
My problem is that this unit *sometimes* fails to recover from the initial reset, after I select a game (bolded above). When it fails, it doesn't make it to the "Now Loading" screen, it just stays black. I'd say failure is 4/5 boots right now.
Things I've tried
PSU is a Lindbergh, voltages are goooood at the connectors
Pi voltage is from the naomi cn4, it's also fine
Changing the target on the pi and the IP address of the Naomi 2
Tried the pi, SD Card, and Net Dimm on a Naomi 1 (they all work fine)
Tried a few Ethernet cables, crossover and not crossover (both work on the naomi1)
Any ideas what to check?
Select game on pi
Things I've tried
