BroadwayJose
I'm having a weird issue or set of issues with my Naomi setup when I use the Sega 837-13551 I/O board. It's somewhat intermittent but it happens often enough where I'm sure there's something wrong somewhere in my configuration. When I netboot into a Naomi game, game does load fine but straight into test mode and I'm unable to move from there. The test buttons on the Naomi don't work when this happens and neither do any controls on the cab/supergun/whatever. If I do get past test mode on the initial boot, sometimes the game eventually goes to test mode by itself or other weird stuff happens, such as the system coins up on its own or certain control buttons (digital only, haven't wired up anything analog yet) are triggered on their own.
I'm wondering if I'm not powering up the Sega I/O correctly. Is there a recommended way to do this? Not sure where to look up that info so here I am looking for the right direction and/or things to read up on.
This does not happen with any other I/O board I've tried, including the Capcom I/O or JVS to Jamma rev B. Those work fine but I'm also looking to avoid having to use those boards in a non-Jamma environment. This is why I have the Sega I/O.
Any help would be appreciated. Thanks.
