@CHAOS0187 What is the name of the game image you are loading and the md5sum ? @RTW the name of the game is capcom vs snk pro.
Or just upload the image you are using, and I'll check itLet me look up some info on how I can get that for you and get back to you on it. Thank you.
https://we.tl/t-VhmTIBwPF5Or just upload the image you are using, and I'll check it
Ok, so I have everything up and running. Pretty awesome stuff. However, I came accross a bug where CVS Pro freezes up on the Geese Howard Fight, right when the dialog begins. Anyone ever had this issue happen? I tried two different brand Cf Cards. Still the same. Bothe CF cards are 512mb. One CF card is an STEC and the other I a Transcend.
Hello. This happens right before the fight with Geese Howard. It freezes during the conversation.Exactly where abouts does this occur? I've just copied the file to a CF and it's working fine throughout the attract screen.
I just tried this app (v1.34) under windows 10, and it does not allow me to select a drive. Tried with WXP support as admin and nothing, so I guess it does not work under W10.You can post here all kind of tools, utilities or programs that help uploading games into the Naomi.
Here is a blog with a tool that will let you upload decrypted Naomi Binaries into a CF.
REMEMBER! You need to get the Card ID (2 bytes) from your card. You need to connect it directly to the IDE bus or via PCMCIA. Other methods like USB adaptors mask the access and wont' allow to see the ID.
http://notinmame.blogspot.co.uk/2012/07/naomicf.html
