Naomi in Time Crisis Cab
Skull Leader
Texas
I'm a noob, and add to that, I'm a noob, trying to do what I think are unconventional things...
I have a Naomi1, with Netboot, and a Type B Jamma I/O (Kind of having trouble finding JVS IO (or do I even WANT a JVS IO?)
What I want to do, is run Lupin III in a Time Crisis 3 Deluxe cab.
The way that I see the system going is that the system246 sends a VGA cord to a converter, that turns it into an S-Video signal, which then goes to a Projection TV
When I plug it in to the Naomi, The screen isn't syncing, and the picture scrolls down.
Do I need a different converter? should I run the picture through the IO, and pull it off of the Edge connector, and turn that signal into something the TV understands?
Also: Are the Light guns compatible with the Naomi and IO? Will the vibration function?
