Naomi or Capcom IO issue? 2P LK stopped registering during play
lupinko
Canada
I had the Naomi setup using the HAS and Undamned adapters. And for some reason for the second player, it stopped registering LK. First we thought it was his stick, but I tried mine and it was the same. I tried rebooting and replugging in the adapters and no go. Then I checked if it was an adapter issue and it wasn’t as said adapter works on 1P with no issues. Then I thought it was an issue with the HAS, so praying it wasn’t the HAS, put in the Atomiswave and low and behold, it’s fine and it registers button 4.
I don’t know if this is a kick harness or Capcom IO or Naomi issue, I’ll check the kick harness later using my CPS2. Any thoughts?
If you still have issues you can make sure the switch to the right of the test button on the Capcom IO is set to 2 player.
