Naomi Pi Power
Big_P Big_p
Australia
While building my Netdimm setup I thought about ways to make it easier to tap CN12 for people. On looking at my first attemps @djsheep suggested USB-C for both it small size as well as to ensure no one plugged their Naomi or I/O to it. He also suggested that a second 5v out maybe useful to people running a USB-C powered I/O or other bits.
Here are the results.
I am currently waiting on more USB-C sockets but in the meantime does anyone know of, and have a part number for, deeper 2.54mm female headers (as standard size ones leave a bit of pin exposed on CN12.
You need the female end of JST NH to connect to CN12.
https://www.jst.com/products/crimp-style-connectors-wire-to-board-type/nh-connector/
These folks in AU appear to stock them: https://www.candycabclub.com/product/jst_nh
You can probably shop around for cheaper sources (and even knockoff ones; I use the knockoffs from China and they are perfectly fine).
Yes; i have tons of them, but it needs to be PCB mounted and as far as I can tell JST don't make a PCB mounted female NH connector.
Yes, you'll likely have to make a cable to connect your PCB.
I personally just make a JST NH to Micro USB cable specifically for powering Raspberry Pis. You may be better off attaching your PCB with a similar cable, but I expect having a cable defeats what you're trying to do, unfortunately.
Dude the idea of the PCB is so you don't need to hack up a cable.
Yes I have done this like 1000 times, I get the deal.
Everything works fine with the PCB, it grips it holds, it powers, nothing has had its purpose defeated. The standard headers I have used leave like 1mm of pin showing. This is not a functional issue just a cosmetic one. What I was asking is if anyone knew of a deeper pin header to fix this cosmetic issue, but thanks for your input.
Ah apologies - I misunderstood what you were trying to get. It's unlikely there's connectors out there that solve your issue unfortunately.
Wishing you the best with your project!
