Good evening everyones,
I took a look at this wire and it seems that some filaments aren't soldered well. With my bad english, I want to say the following : a wire is composed by x number of filaments and a sheath. The resolution of my pics isn't very accurate but I can see that some of the filaments are broken (that's my feeling), and only a few are soldered. In this specific case, is it an issue? Is it important that each filaments should be soldered or should I cut and solder again? If yes, can I use my former tool (crimping tool?) I usually use to make 18 and 24 awg wires naked (denude/strip)? This sheath looks like thicker than a standart 18awg.
Thank you!
Thank you!
