So I purchased a PCB for street fighter II on ebay and low and behold it was bootlegged. That was my fault that I didn't read the fine print. It is an "MSTREET-6" board if I am reading it correctly. My JAMMA harness doesn't look like it will fit as there is a notch in my harness and the pinout on the board has no space for the notch to fit into. And how do I connect the kick harness? Here is a picture of the board:
Remove the key in your jamma harness, or drill a notch in the pcb, or use a pcb fingerboard or something like a jnx voltmeter that doesn’t have a key in it. http://www.jamma-nation-x.com/jammax/store.html
And don’t plug it in upside down…
kicks look like those last couple pins with the wires. Hard to see what they terminate in connector-wise. Maybe they also do kicks on one of those pin headers but I’m not sure (have a multimeter?)
Depends what you prefer and how your cab takes extra buttons but there are solutions.
