Hello everyone!
I'm looking for advice on powering my MVS cabinet. The original power supply is on deaths door. It's the original power supply so nothing janky, but the replacements are pretty hard to come by https://na.suzohapp.com/products/power_supplies/80-0072-00
I would prefer to keep the cabinet as stock as possible, but I play it almost every day and need a reliable, quick fix without resorting to anything jank.
I play around with old PCs, And have several high-quality ATX SeaSonic power supplies on hand. I'm considering desoldering the connectors from the old MVS power supply and wiring Molex and 24-pin connectors on the other end to make it easy to swap in ATX power supplies in the future if needed.
Do you think this would be fine? I know most people recommend using a switching power supply, but I’d rather use what I have on hand in bulk.
I'm also thinking about rebuilding the original power supply. I could temporarily use the ATX supply while I work on fixing the original one.
I've also been told that this is a direct drop in replacement, but in atx instead of xt https://www.gameroomguys.com/Dual-Switch-Power-Supply is that true? Looking at it it does look like it'd work out of the box, but wouldn't mount right.
Thanks for your input!
