Neo Geo PCB - what buttons?
decimata
Marlborough, MA
I have a original Killer Instinct arcade machine which has 6 buttons + start for each player.
If I where to swap out the PCB for a Neo Geo PCB, what buttons would the Neo Geo use?
A single slot MVS should plug in and you'll get buttons ABC on the KI punches (button D will not be connected). Start, coin and service buttons will work normally as well.
if this is a multi slot MVS you'll need an adapter because they uses a non-standard JAMMA pinout.
